- Aug 7, 2007
- Manual
It's far from an achilles heel. The slaves run similar lifetimes to the clutch, and require almost the same effort to change.
Release forks have their own issues. Not the least of which is that the release bearings don't last as long with the off-axis forces, and that requires pulling the transmission....
Before reminiscing about the "old days," do keep in mind that comparable truck transmissions weighed a WHOLE lot more back then. My SM465 is 150 lbs. No transfer case. It takes an engine crane and a hole in the floor to install that.
And any guy with a decent jack can do this. You don't need a dealer.
I'd expect the dealer would want 10 bills for this. The corner mechanic, probably half that.
