clutch problem
882wdrngr
I just got a ranger thats been sitting for 5 years and got it running great the only bad thing is it won't move and i think it has something to do with the clutch because you can move the stick around without even pushing in the clutch pedal If you guys can give some suggestions please do
Welcome to The Ranger Station!
Search using the terms "bleed clutch" and read up. Might also search on Slave.
Your worst case is that the trans is shot, but yours sounds like a clutch problem to me. Not that hard to replace the clutch, but having help, helps.
If you can put the trans in gear with engine running and clutch pedal out then the clutch disc, pressure plate or trans input shaft has failed. Time to pull the trans out!!!
