- Nov 11, 2007
- Manual
93 ranger just had work on manual trans ( dragging in gears) after work would not shift in gears while running. i took back and mech bleed and said it was low on fluid. All was well for a while and after letting it sit for a while I noticed it was low again. I refilled but can not shift when engine is running. I can not see any signs of a leak at master cylinder. I opened view port in bell housing of trans and did not see any leak at slave cylinder. how can I tell if either is bad or do i need to just bleed system again.
