clutch master cylinder
davidbmd
Can I rebuild the clutch master cylinder
Can the line be removed to save it
Is a seal kit available as my bore is clean as a wistle
can a complete master cylinder be bought with the line attached?
Thanks
the line can be removed with breaking it. If its original good luck. More than likely it wont come out and will have to be broke. And you can buy a master with line attached and pre bleed.
I just changed the clutch and slave and master and didnt break anything..... its all how you do but from what I have been told.. buying the slave and master hooked to the line already bled is better.. ya you will spend extra dollars but its worth it in the long run.... trust me. I went the buying everything seperate and it took 4 hours of bleeding the line to get the clutch to work properly.. If I had the vacuum pump it would have been easier..
If it took you 4hours to bleed the system then you did it wrong. It should take maybe 30 mins if your bench bleeding, which is recommended to make it easier.
