Clutch Master Cylinder Removal
Steeda04SVT
U.S. Military - Active
Clovis, NM/Cannon AFB, NM
Done some research on here trying to find tips on removing the push rod from the clutch master cylinder. I removed the interlock cannon plug that plugs into the interlock switch. I removed a lil clip that goes around the the master cylinder under the dash which lets the interlock switch slide up and down the rod. But can't figure out how to take the rod out of the master cylinder. Any ideas? Been trying for the past 30 minutes just yanking on the the rod and it's not popping out.
Some say to use a couple of small screwdrivers at the balljoint in the end of the mc.
I just yanked mine..............though my mc does not retain my pushrod any longer...
