clutch issue
swamprat
lexington KY
I swapped out the a4ld for a m5od. I am having a bleeding issue. I bench bled the master and line. Rock hard pedal. Pop the line in the trany and gravity bleed a couple res full and close the bled screw. Start the truck and cant get it in gear. Never had such a hard time. am I over looking something? New slave and master installed. Pressure line from master came from 4.0 m5od combo I had. Used clutch and flywheel from my BII that had a 4.0 swap and I am using the m5od that I had in the BII
When I disconnect the quick disconnect I get a pop of fluid out of it.
1994 ranger 4.0
