Clutch Hydraulic Line
diehard80's
Riverside, CA
1987 (x2)
Okay... I'm removing the transmission in order to replace the clutch (and possibly the slave cylinder) but I'm confused as to how to disconnect the clutch hydraulic line. I have an '87 Ranger 2.9L with a 5-speed M5OD transmission. Chilton's manual says to slide the white sleeve down toward the slave cylinder but I don't see any sleeve. Does it come out using the same kind of tool used to disconnect "quick-connect" fuel lines?
Most trucks that age don't have the sleeve anymore. I took a hose clamp of around the right diameter, pried off the worm screw part, and then stuck the clamp around the connector and worked it in there with a flathead. It takes a while but it works.
On another truck i literally just pryed the slave side (it came apart in chunks) of the connector away from the master input. It destroyed the slave but i was replacing it anyways.
I've had pretty good luck using two flat head precision screw drivers
