- Jan 22, 2009
- Pryor, OK
- Automatic
I'm sure I'm the million and one-th person to have problems with this....the things I would do to the engineer that came up with this would put me in prison for multiple consecutive life sentences...
The slave cylinder disconnect...my manual is no help at all, and I've never done one of these with the internal slave cylinder so I'm shooting in the dark. Combine that with the apparent mangling of years past and I'm lost. I've found plenty of relatively short references to it here on TRS, but nothing descriptive enough to provide much help.
I'm going to refer to the visible sections as the "hose" which is strictly the black hose, the "largest cylinder" which is the big blue part, and the "intermediate cylinder" which has a little metal ridge around it and a dome surrounding where the hose enters.
What I've ascertained:
All of these three parts will rotate independently of eachother.
There appears to be remnants of some sort of plastic sleeve between the two cylinders. Don't know what it is. Hoping it's not important.
The intermediate cylinder telescopes slightly (about 1-2mm) into the large cylinder.
I've been working this telescoping action using a screwdriver prying against the bellhousing case to force it...it doesn't move by pure hand pressure alone. Pressing it in while pulling the hose doesn't appear to be doing anything.
I've sprayed the hell out of it with PB blaster.
What I don't know:
After separation, does the intermediate cylinder stay with the hose or with the large cylinder?
What am I doing wrong here??!!
Help me Obi Wan Kenobi, you're my only hope!
What I don't know:
