clutch fan problems
flowranger
I have the stock clutch fan on but the plastic is cracking and warped.
whats the cheapest way to go a flex fan bolted straight to the pump or buy a new plastic fan. if so where is the cheapest place to buy one because im really short on cash
My clutch was bad and the fan was cracked as well and it had a blade bent. I took a gamble and got the whole thing at the junk yard for $32,and they even let me use the wrench to change it to make sure it worked. It must be a design flaw that the fan cracks because the one I got was cracked also but it was better than the one I had and the clutch must be good cause it runs alot cooler.
I would definitely grab one from the junkyard.
