Clutch Compatibility for 1994 3.0
Thew
Forum Member
Seattle
N/A
Vehicle
Drive
3.0L
I am looking into options for replacing my clutch and am trying to sort out what my options are.
I drive it like I stole it, regularly deal with starting/reversing on steep hills, have a camper built out in the back, will be towing a boat, and doing some forest road adventuring this summer. Additionally, I'm hoping to swap in a slightly beefed up TDI once my current engine gives up (could be a year, could be 3, who knows). As such, if I'm going to put in the effort to swap the clutch, I want to make sure it's the stoutest option (reasonably) possible.
Looking at these two:
3.0 stage 4
4.0 stage 4
The clutch for the 4.0 is larger and has a ~10% higher hp/torque rating, so I'd like to make it work if possible.
Is this feasible? If so, what mods would be necessary? A 4.0 flywheel and starter? Am I overthinking it?
Replaced the master and lines a couple weeks ago, though I think it may still have a small bubble trapped as it occasionally (maybe 5% of the time) gives a soft pedal.
Other similar threads on here seems to launch into a bunch of tangential debates without a real definite answer so I'm hoping someone can sort me out.
I don't have experience with either of those. My gut feeling is to stick with something built for the 3.0l. Mixing and matching different flywheels, starters, etc. Seems to cause more headaches than it solves.
Yeah, that..
I've been very pleased with the performance and longevity of the Centerforce setup I started using 15 years ago, they don't make a kit but the pressure plate and friction disc are CTF-381009 and CTF-CFT360032 which can be bought on Summit easy enough, you'll just need to get your own pilot bearing and slave cylinder/throwout bearing. It drives just like a regular clutch but has held up to my abuse, I changed it when I rebuilt the transmission a couple years ago but turns out it was perfectly fine... what I pulled off will go on my '97 when that clutch finally gives in...
Yeah, that..
Finally circling back to this now that my throwout bearing is whining, do you know if the 2.3 clutches fit 3.0? The specs seem like it all matches up but that seems too easy.
As far as I've ever heard there were only two clutches for the Ranger with the M5OD: The 4L with bigger contact area/flywheel and the rest (Lima, 3L and Duratec). I know the 2.8/2.9/4.0 guys all use the 4L clutch since they can so I'm like 99.5% sure the 3L and the rest use the same clutch
well I just ordered the last level 2 pressure plate and disc in stock from centerforce directly, thanks anyways lol. Their website said it was compatible with both 2.3 and 3.0, weird that most other sites differed. They were actually on sale and cheapest through them directly
If you got what I did I like how it works, never have been able to slip it unless I wanted to but I don't have any low end power...
