- Dec 20, 2013
- South Western Ohio
- Manual
I have a 1986 4X4 Ranger with a clutch issue. When I first got it, the clutch was at the floor before it would release. Over time it got to the point that it would not disengage. After checking everything I discovered that the bolts came out from the bell housing to the engine. I replaced the bolts and the clutch worked great. I also noticed that fluid was seeping out of the clutch master where the ram goes into it.
NOW, my clutch does not work again. The pedal feels normal but it does not release at all. It's just like when the bolts came out of the transition, but they are right where they should be. My thought is to bleed the system before I go any farther. I'm sure there is air in the master as much as it's leaking.
I can not figure out how to get to the bleeder screw. It's at the top of the transmission and I can't even see or feel it. Am I not looking in the right spot? I have a master and slave laying on the ground to look at for reference, but I can't find it on the trans.
My next question: I saw a video of a guy who pulled the piston out of the master from under the dash to release the air. Will this actually do the trick, assuming the air is in the master and not the slave? Looks fairly easy but I wanted to get some feedback to make sure it's not just a spoof.
Thanks for all of the help!
