- Feb 20, 2008
- Northern Minnesota
My 94 3.0 did the exact same thing...the clutch plate was just about shot and was starting to groove the cover a little....I replaced everything at the same time, master and slave, clutch cover, and plate...i didnt have the tool to remove the quick connect so i pushed out the roll pin holding the line in on the old slave cyllinder and cut the end off with a dremmel tool end put it all back toghether..I jacked the whole truck a foot and a half up on blocks and stands. Used a regular floor jack and had almost no problems except 4 broken exhaust studs....a cutting torch fixed that problem though....Good luck though!!!!
