Clutch acting up
Get under the dash and look at where the clutch pedal linkage rod goes into the master cylinder. I've had them leak there, and the fluid runs down the firewall behind the carpet so you won't see it unless you look.
Hi Ron,
Yes, level does seem to be dropping, only topped it up once so far but keeping a close eye out, as well as the ground. As you say I should be able to keep topping it until the location becomes obvious.
Tthanks again Ron! Pulling the trans is like the old days, drive shafts, cross member, transfer case etc? Oh boy…
Will do, thanks Robbie.
