clunk and shakes
stockfornow
eau claire wi
i have a 89 ranger with the 7.5 rear axle. when i shift from reveres to drive and back again. i can also fell vibration coming from the drive shaft when doing 65 MPH. i have already replaced all u joints and the carrier bearing. i also have a little play on the yoke on the diff. If anyone has a clue what is wrong any help would be appreciated.
If there is play at the pinion of the rear diff that's probably where your problem is, there should be zero play in those bearings. If its been like that for a while there is a good chance the pinion bearings are hosed.
