Shawn6880
- Apr 5, 2015
Hello RS members, I'm a new registered user but have been a guest numerous times. Going through my midlife crisis which seems to be learning about cars. I need your help with this one. Trying to install the clock spring for an air bag code. Broke original not locking steering column during steering box replacement. Broke number 2 misunderstanding install directions. Are the new OEM clock springs centered for install? Yellow pull tab on spring. Sticker tells you to recenter depress tab,turn towards arrow until stops. Turn opposite direction approx 3 turns. Do this only if yellow tab has been pulled? Anyway followed shop manual install directions, tested the steering slowly with wheels off the ground and broke the second one before one full turn. Number 3 showed up last week
Was wondering if anyone knows what I was doing wrong. And if you have a procedure list how it is suppose to be installed correctly.
Thank you in advance. Shawn
