Cliffs Insane Terrain
Beef52751
Eastern Iowa
Would anyone be interested in a spring run to Cliffs Insane terrain??? I have never been there but its about 2 1/2 hours from me and if we could get a group of trucks to go it would be worth the drive.
I may be down for a trip out there, Only issue is my bone stock truck, I wouldnt want to make the trip out if all I would do is get left behind lol.
Let me know. I go there all the time. I need more dents and creases in my bed sides.
Rock you may want to change your info on the light off road if ya go.........JK we'll take it easy on ya.
Getting the truck into something other then ditches and cornfields is seomthing I am really looking forward to, and come spring I am going to be putting a lot of work into my truck to get it into tip top shape for some good fun.
I drive 2 hours. I would say yes.....others would say no. Just due to the fact that they have been to better places with more land and trails.
is it likely to tear up the body on my truck? ie. tight wooded trails, etc.?
The body damage can be minimal if you want. I go down some of the tighter trails as my truck is trailered there and back. I went down a trail called "Land Cruiser", it was right before "Jimmies Crack" and that was where I got the most body damage of the day. I had to use the winch on the rear of the truck to get around a corner. There are other trails there too but the full size trucks would be worthless on them.
there are many trails, some are a drive on dirt, and others are an extreme wheeler's battle...
I went there a few weeks ago with my stock 89 STX and had a blast...
If anyone goes me and my buddies would be interested in going...
Here's the thread when we went...
http://therangerstation.com/forums/showthread.php?t=118408
Those are some good pics there Gary. The full size trucks hindered your fun for the day. That place is not full size freindly unless you really don't care about body damage. Although I am surprised that they let them out on the trails as they have a wheel base limit. But anyway let's definately setup a spring run to go there. I will get my buddies and hopefully Bray will follow us up too.
my truck will probably be trailered there because my powerstroke drives way better and with a D28 and 33s i doubt it will be driveable to get home. are winches required?
You don't need a winch. I have 2 on my truck (front and rear). Most of the people I go up with have one so you will be just fine. Just don't follow me and the places I go. I also have on-board air too. I go prepared to help others and not just myself.
then i want to make sure your there when i go, because this will probably be the first time i really get to abuse the truck so im expecting some failures lol
Thanks!
I dont recall them even checking on a wheelbase lenght...
That was my first time out and i had a BLAST! before that i had never used 4x4. I was VERY impressed with my truck!
Bad a$$! you are set!
My truck is completely stock with worn tires, i went there with no winch and had no problems! I expected things to break, but nothing happened...
Drove it there, wheeled all day, and drove home...
I'm willing to go too, I also might drag a couple friends with me and I might trailer Liz up there too.
