- Nov 30, 2001
- Gnaw Bone, Indiana
- Manual
You blasted the engine with 1,000psi of water. It's not it's fault. There's water in something.
Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
honestly, i would have no clue what it sounds like haha....
It makes a buzzing sounds, similar to the noise your refrigerator might make. This is always easier to hear if you have a friend turn the key for you while you put your head near the tank, it will only sound for about 2 seconds when the key is turned.
we tried that, still didn't work. but like i said, it engages (belts move and such), so it can't be the starter can it?
with a bad starter it just goes "click click click click"?
Inertia switch is under or right above the carpet under the dash on the passenger side. The fuel pump relay is on the passenger fender under the hood. It's a little black cube with wires attached to it. Should look something like this...
I would seriously look at fuses and the pump relay before you go replacing pumps. Pumps don't usually just die suddenly. And yes, you are right, there are two pumps, one on the frame rail and one in the tank. The one on the frame rail is the loud one that you can always hear when you turn the key to "on" and the one in the tank is much quieter.
One more thing to look at is the ground for the fuel pumps that is connected directly to the negative post on the battery. It's a small wire about a foot long with a connector on it. I have accidentally unplugged that before, which makes the fuel pumps not work.
i will drive down to work and look for those things.
i've seen a black ground come off the black negative terminal of my battery, and it goes directly straight forward towards me (if i'm standing in front of the truck) and is connected to a bolt.. is that the ground you are talking about?
i will add some things to the list before i buy a fuel pump... wait will i need two if i am replacing? isn't there one mounted in tank and one outside of the tank? a low pressure and a high pressure? which one is bad if it doesn't start up?
