Circular saw storage rack/shelf
Shran
Junk Collector
Solid Axle Swap
Truck of Month
Rapid City
SD - USA
Anyone have cool ideas for storing circular saws? I am looking for something that will mount on a wall or pegboard. Simple would be nice. Compact is a necessity. Something I could buy off the shelf would be OK.
I have two corded ones and four cordless, currently they are just stacked up on the bottom shelf of my workbench. It would be nice to have a rack for them or something.
Step 1. Thoroughly clean/ blow all dust and dirt from the machine.
Step 2. Remove blade and reinstall blade nut on arbor
Step 3. Place saw back in original packaging.
Step 4. Neatly stack saw (in packaging) on shelf in power tool cabinet. Note; shelf should be properly labeled to denote location for each tool.
Step 5. Close cabinet door.
Step 6. Don ballcap that says "Nerd" on the front and "kick me" on the back.
I'm thinking a lazy susan would be handy if you switch saws often.
J hooks on the underside of a wood shelf.
I like file folder cabinets. The wider ones used in commercial applications have great slides as paper is very heavy. You can find ones that are 2, 3, 4 ,or 5 drawers high, so the shorter ones can serve as base cabinets for a work surface.
Sadly, I do all but 6... So I deleted it. lol
