Choptop SAS BII
fuelie
White House TN
After months of searching, i found this 89 BII with the worse chop imaginable.
Choptop SAS BII
So first step was to start capping off the sheet metal with some 1x3 tubing.
Choptop SAS BII
Choptop SAS BII
Choptop SAS BII
i will update more as i upload more pics.
worse imaginable?
The previous owner cut around all of the pinch weld for the windows with what appeared to be a dull hatchet. i still have a couple of spots to finish. I am trying to find some pictures with the tubing finished.
I'd like to see lots of pictures!
Plans for a top?
I did mine similar to that, with sheet metal though, then chopped down a short bed ranger camper shell.
Also, I grafted the rear top portions of a Ranger bed above the taillights, and make mounts for a tailgate. Made it look finished.
That was before smart phones and I couldn't afford a digital camera, wish I had pictures...
I found a few more pics of the metalwork. I cut down the rear hatch and moved the hinges to the bottom. As far as the top goes i made a temporary partition for the winter, but i have a couple of different ideas in my head.
Choptop SAS BII
Choptop SAS BII
Choptop SAS BII
Sorry about the poor inside pic. I cant seem to get my camera to take good pics inside the shop.
Now on to the straight axle swap. Im using a d30 hp. When i moved the coil buckets on the axle i went ahead and moved them 1 inch behind the centerline. I plan on moving the frame coil buckets 2 inches forward to stretch the wb. I'm wanting to get 100" wb when im finished.
Choptop SAS BII
Choptop SAS BII
I have been too busy lately to get much done on the bronco, but i did manage to get started on my lower arms. I need to pick up more steel before i can go any further.
Choptop SAS BII
I would like to see some more pictures of how you cleaned up the chop. Please?
Steve
I don't have any more pics while i was capping the sides. Here are a few more after photos to give a little better idea of what i did.
Choptop SAS BII
Choptop SAS BII
Choptop SAS BII
It was alot of work, but it was the only way i was going to be satisfied with it. It will still require a little attention before paint.
thanks for the additional pics. I like what I see. So what are these other ideas you have for it?
Steve
Haven't had much time lately to work on anything, but i did manage to recover my headliner.
Choptop SAS BII
Choptop SAS BII
Also done some wheeling this weekend and managed to bury it.
