Chirp noise near back of truck upon takeoff?
  • Thread starter Thread starter Mike Tonon
  • Start date Start date
Mike Tonon
Guest
So, after doing about half dozen burnouts one day, my truck now has a quick chirp noise upon takeoff. It seems to be coming from the rear axle, but I suppose it could be coming from the throwout bearing or slave? Just after this issue started, I changed my rear diff. fluid. I didn’t see any chunks, but lots of little metal flakes and the fluid was black. What do you guys think it is?
Let let me tell you a little story, we replaced the two piece with a one piece driveshaft in my truck, new universals installed by a machine shop.
past couple months I've had a chirping noise in the back like you're describing, also the truck has had a shake at 35 55 65 mph had me convinced the rear end with shot. took it to a shop confirm what I was already pretty sure of. ?
They dropped the shaft off the back flange cleaned the flange of rust, greased the new universals, put it back up, started& ran it at high speed with the wheels spinning while on the lift. he put a pencil against it and showed how it was running very very smooth and not making the chirping noises anymore he also showed me which was pretty obvious that both of the nearly new tires had flat spots on them,. new tires no more shake no more chirp! ?
