- Nov 20, 2008
- Automatic
Hi Everyone,
I am new the the forum and to the Ford Rangers at all and I need your help.
I bought my Ranger like a two weeks ago, and just started to run into problems with it, which is understandable , it's 1996 4 cyl. auto transmission with 85K miles.
Now to the point, last week it didn't want to start without pressing on the gas, which I should not have to do(it's FI). Anyways, after pressing on the gas it will start, but when cold it will just die if released(I was driving with the left foot on the break and the other on the gas). When warm the engine was going very low with the RPMs (like at stop lights). Engine light at that time was not on. I thought it might not work and went to Advance Auto Parts to have them check and see if we can retrieve any codes....and nothing. On my way home from there, the light came on, and I just decided to go to Ford Service for diagnostics.
What they found was Error Code P1359, which is Spark Output circuit fault. They have "Reprogrammed the PCM with latest calibration"...whatever that means.(I hope they didn't just disconnect the battery for an hour to clean the codes).
Now, the truck runs good, but I am afraid that they didn't eliminate the cause of that, and that it will happen again. The guy there suggested that I have the throttle body flushed...whatever that means, and it will cost me like $200....which I prefer to spend on some sensors if some of them are dead.
Please advise. What should I do ?
Thanks.
Thanks.
