Check Engine Light help?
Ryannn
Carson City, NV
I pulled my engine from a 1990 B2 with a Mas air flow on the air box end, I dont have that on my box. Would this cause the Check engine light to come on?
-Ryan
Did you take the computer? If you used your computer, then there shouldn't be an issue. Get the codes and come back. There is an article on it in the library.
On an unrelated note, if that B2 had a manual, can you grab me the computer and air box?
I used my computer yes. Ill pull the codes.
The B2 Was in a junkyard and they moved it... Sorry man!
I'll keep an eye out when I go to JY next. But I haven't seen a b2 yet in one around me, only full-size broncos.
