Cheap lift
n_bannerman
Walla Walla, Washington
im looking at swapping out my coils for a little bit taller ones and was wandering who makes the softest coils and if a 4 inche lift coil would be to tall for getting the camber set correctly on a stock 88 ranger.
thanks for the help,
nathan
to use 4'' lift coils you need the lift brackets to. it you are looking for a little more highth then you can put in f-150 coils or 4-door explorer coils. you can get a 4'' lift kit for under $650.
well im just trying to get a little lift with out doing spacers for some 31's till i have enough money for an autofab longtravel kit and my current coils are sagging majorly
will it be fairly easy to get the camber correct again and have the front end re-ailgned again, i will be doing alot of driving from the south east part of washington to the north wet part and this is my only rig right now.
It costs me $188 at a shop to have the F150 coils installed and realigned, it added about 1.5 inches in the front.
I just found some 2 inche lift coils from skyjacker and was wandering if those would work to make 30's or 31's fit? i want a smoother ride and dont want to have to bend or drill holes in the coil perch's or towers.
