Cheap Lift
yeah they are. but tuff country is a little better. they use an actual passenger side drop bracket instead of a drop plate.
you asked if there was a cheaper one
Alright is that pretty much it. I'm not going to use the rear lift of the kit. I'm going to do a 63 inch leaf swap and shackles in the rear. Is there a place were I could just get the front kit??? Or am I better off buying a used kit here, or just buying the kit and not using the rear lift???
i bought mine off of here a few pieces at a time. i got the drop brackets and 4" coils shipped to my door for $110. not a bad deal. i've pieced together the rest as well. probably spent ~$400 on it so far. that's using explorer rear leaf springs and extended shackles, extended brake lines and rancho shocks. 4" drop pitman arm and radius arm drop brackets.
if you dont need a rear lift, i'd poke around on here, check the classifieds section, there's a few lift kits in there right now
