2ruble
- Jan 3, 2017
- Loganville, GA
- My credo
- "Don't trouble trouble until trouble troubles you"
I replaced my battery with an AGM battery and also 80amp alternator last night, I didn't "charge" the battery after running around with just the battery running the vehicle because I figured the alternator would do it driving around for about an hour last night and the drive to work this morning. My question is that under throttle the voltmeter is coming up fine, above middle - at what I'm assuming is about 14v. At idle, on occasion, it would drop down to below middle, closer to what I'm assuming is 9-10. I can't remember if I had the heater on at idle or not, but that really shouldn't drop it I wouldn't think.
I tested last night after install, the battery was at about 12.32 after alternator install and under rpm it registered about 13.4, under load it dropped a hair, but stayed above 12.
It's an 89 bronco ii 2.9 with A/C (doesn't work) but the heater blows hotter than hell.
Ideas? Or I just haven't let it charge enough?
