Changing the backlight colors
7aawilson
Forum Member
Kennett Square
PA - USA
Vehicle
Drive
Stock
Stock
30 inch
I have an 06 ranger with the classic green backlit gauge cluster, is there any way I can get blue bulbs for it? I'm not sure what size or how many id need to get, I just like the color blue more and think it would look nice.
Never had a 06 apart. But if the cluster takes regular yellow bulbs, then it has green lenses to change the light to green.
I have had the early 80's and 90's Ford truck clusters apart, they had a green lense that you can poke out with a pencil. These got cloudy over time and would not pass much light. Once you do that, you can just use the regular bulbs and have a yellowish light, or buy colored LED bulbs in the color you want and use those.
You will have to take it apart and investigate if someone else doesn't have more info.
On my '96, you can remove the cluster and peel of the gauge faces, scratch off the green filter and add blue LEDs, as I did. According to this video, you can't do it on yours. He added blue LEDs and got turquoise.
