Changing speedometer readings
47papa65
1994 mazda b400
i just replaced my rear end . I went from 3.55 gears to 3.08 and now my speedometer is off. How do I fix this? Thanks.
I believe for a 1994 will have to take the little plastic gear that controls that out of the transmission to see what color it is, the color coincides to a number of teeth, you will then have to use a calculator you can find on this site under tech articles find the new number of teeth you need to correct your speedometer and order it. I believe it is called speedometer worm gear or something like that.
