- Apr 27, 2013
- Gaithersburg, MD
- 4.0 V6
- Automatic
Have done some coolant flushes over the years using the owners manual recommended Motorcraft VC-7-B "gold" colored coolant. In the past my brother could get it at his cost so cost was about the same as the generic plain ole green Prestone ethylene glycol stocked in Advance Auto. That has been used forever in cars and trucks.
But he can no longer get the VC-7-B economically for me. And it's time to do a coolant flush, as its overdue. So when I change out the plastic thermostat housing for the Simonz aluminum unit. I want to changeover to the green Prestone ethylene glycol mix.
Is there any reason not to do that? It's cheaper for me, that coolant is easier to get, can be found anywhere. Seems like a no-brainer for this nearly 15 yo 2011 Ranger w/ a 4.0 sohc V6?
And what is the easiest way to drain the block fully? In the past I've had to resort to several iterations of plain water changes, drive for awhile, repeat to get the system to drain clear. And even then I believe there was still a lot of coolant not drained from the block.
I would drain by the radiator lower petcock first. Then remove lower rad hose and by squeezing upper rad hose to try and get the last bit out. There does not seem to be a block drain like my old Toyota truck had. You have a better technique?
