Donthekawguy
Just changed the housing and sensors last week. I took off the throttle body and idler pulley to get it in and out. The inside of the throttle body was filthy so grabbed a can of what I thought was TB and carb cleaner and gave it a doosh. Also when I installed the new housing I notices the sensors were a different size then the stock ones and the passenger side sensor wouldnt plug in. The part that slides in the groove on the plug were in a littlw different spot. So of course I shaved those off to get the new sensor to plug in. Lol now its hard to start and when I push on the gas it stumbles and dies a few times. After I put it all back together is when I noticed the brake cleaner TB cleaner mix up. I think I'll try taking the TB off and checking things out there first but the sensors have me puzzled. The houaing is the correct one just upgraded to the metal one. The new sensors came with it and you would think they would be the same size as the old ones but they are bigger around.
