changed my 02 sensors, now no axcelleration
Denny1
My check engine light came on , and my code reader said a bad 02 sensor. I changed that ,now it won't exellerate.I only changed the two up stream ones.
when you say you changed the O2 sensor did you use a OE one or aftermarket. Could it be a wiring issue?
Delphi
Violet Signal +
Pink Signal -
Brown Heater
Brown Heater
Denso
Blue Signal +
White Signal -
Black Heater
Black Heater
Bosch
Black Signal +
Gray Signal -
White Heater
White Heater
NGK
White Signal +
Green Signal -
Black Heater
Black Heater
Locknar
I bought the Bosh sensors, My code reader said that the up stream ones were bad. I don't understand why it won't exallerate , I mean these sensors just plug in . Thanks for your help, Denny
