change in flywheel?
scotts90ranger
RBV's on Boost
Dayton
OR - USA
Drive
2.3 (4 Cylinder)
35"
on partsamerica's website they show the flywheel changing after '94, did the bolt pattern change?
a few months ago I got a flywheel for my ex's parents '94 ranger, it didn't match up to the crank, so I still have it sitting in my garage. what are the chances of the engine being a late '94 with the '95 crank? same deal with my truck being a '90 but is mostly '89 parts
does anyone know any measurements on the bolt pattern of the early or late flywheel? either would work as I just want to know which it is so I can get rid of the thing, I've already taken in the core and lost the receipt and don't have the packaging because they took it with the core, so I can't compare part numbers...
Thanks for any help!
Should bolt right up,all the 2.3,s and 2.5,s that we have run,same bolt pattern.1.9 escorts always so work fine and save quite a bit weight.
