Center Console Wiring Diagram/Pics???
NJ
Hi all. Trying to install an original center console on my 88 B2. I have the original harness with it but I am not seeing where it plugs to under the dash. I do have a blank plug directly center of the dash (like right behind the shifter, see attached pic). I thought that was for the console but the harness has several different plugs on it. (as a side note, anyone know what this empty plug is for in my pics?????)
Anyone have a wire diagram of this or even better pics of where the harness attaches at under the dash?
I have the same problem. Bumping to see if there's an answer out there
That picture looks an awful lot like one of the radio connectors
It is similar. Here's some photos from my truck. Can't get a good pic of the connector in the center console because I have to remove it. But it seems there is a missing harness that may go to this connector under the dash
I used this and just tapped into the harness
Is this the same harness for 1988? The center floor console in my truck only has LED's to display low fuel, low washer fluid, and bad indicators.
I honestly do not know if it's the same
