if you have a cigar lighter that is not being used you could disconnect it and use the power and ground feed for the cigar lighter as the power source for you CB. otherwise look at your fuse panel and see if you have a constant 12V power source or a keyed[accessory]12V power source and go with one of those, keeping in mind to ground to the chassisi just bought a cobra 19 ultra III and i dont know where to wire the power wire to. is there anywhere in the cab it can be wired to?
how do i know which is a constant 12v power source on my fuse panel
The correct way to wire a transmitter is to run power into the cab directly from the battery. This includes both positive and negative leads, and both sides of the leads should be fused as close to the battery as possible. This prevents RF from getting into the vehicle wiring, minimizes noise from the vehicle getting into the radio through the power leads, and avoids a voltage drop using the vehicles wiring, assuming you are using wire of adequate gauge. I would recommend at least 12 gauge, but for a CB, 14 should work ok, since a CB doesn't a lot of current.
