Caster
Rulebreaker
Solid Axle Swap
Manton,MI
Anyone know what the caster range is for a 79 Ford 1/2 ton with the HP44? My Hanes manual doesn't say. Thanks RB
well my machine tells me a 79 f150 4x4 exc supercab
camber 1.50 tolerance of -.5 +1.50
Caster 8.00 -1.50 +1.50
Toe 0.18 with -.26 +26
but an 78 is
Camber 1.5 -/+.5
Caster 3.5 -/+.75
Toe 0.18 -/+.13
but an 78 is
Camber 1.5 -/+.5
Caster 3.5 -/+.75
Toe 0.18 -/+.13
Thanks, I'll use the 3.5 as I'll have to build a 8" Radius arm drop along with my 7 degree C bushings to get 3 degrees so 8 is ridiculous. RB
Could I use an adjustable upper ball joint like in the D35 TTB? That would allow me to build like maybe a 3-4" radius arm drop, which I would prefer. RB
i'll have to check my book at work and see what they offer, if they do i'll have a part number for you
okay napa numbers i got
+/- 1.5 degress (goes with the upper ball joint) #264-2065
they also have shims that can go between the spindle and knuckle, looks like adjusteable between +/- 1.5 degrees (flat shim, looks like a wheel spacer)
6 bolt spindle #264-1971
8 bolt #264-1973
