caster bushing degree
Gloucester, Virginia
I have installed a 2" daystar coil spring spacer, and I was wondering what degree(s) I will need for the bushings to do the alignment?
thanks. oh it's a 1992 Ford Ranger 4x4 STX
It will vary a bit with every truck. To do it properly, you should take a measurement after you put the spacers in to determine the bushings needed.
If you're doing this yourself, the best bushings to get are the 2-piece fully adjustable ones (Ingalls 594, etc.), as these can be set to any amount of degree needed (and will also allow for future adjustment if you decide to change something in the suspension at a later date). :icon_thumby:
