85_Ranger4x4
Wallers in rivers
💻 TRS Socials
- Aug 7, 2007
- Frankfort
- State - Country
- IA- USA
- Manual
A couple years ago dad picked up a 1955 gas Case 400 tractor. It was a basket case with the heads off and block cracked… but it was all there. So it went to the back of the fridge to chill until a solution came up, and it did in the form of a good running 1960 Case 830 gas being parted out in Kansas. So he drug the engine home and my brother and I are going to help him swap the 251 (4” bore x 5” stroke) for the 830’s 284 (4.25” x 5” stroke) it also has bigger valves and an extra point of compression that takes it from 53hp to 65hp on the PTO. The beautiful part of this swap is, aside from the tin the rest of the tractor is essentially the same as the donar so no durability or cooling issues should crop up.
Kind of amazing how tall the thing is, kinda wonder what it weighs too...
Either the rear seal or the softplug is leaking, both are going to be replaced.
Had to buy the "good" clutch to get the flywheel which is a different part number from the 400's. Since they are no longer available it wasn't worth the chance to let it go. The clutch probably worked good but it isn't good enough to put back in considering the work to get at it. Splitting a tractor isn't much fun... especially if you were just there.
