- Aug 6, 2007
- State - Country
- GA - USA
- Vehicle
- Ford Ranger
- Automatic
- Total Drop
- few inches
- Tire Size
- ~30"
Planning to acquire a cargo trailer for storage around the house for a few upcoming reno projects and eventual build up into a minimalist toy hauler camper. I have got bigger trucks, but I would like to be able to retain usage of the Ranger for towing when I'm not carrying any toys.
When in say minimalist I mean it. No shower, no bathroom, no onboard water storage. Most of my staying will be at locations with bathhouse facilities, or I will setup an outdoor toilet/shower arrangement when needed. It will be all electric with an onboard fridge, convection microwave and hotplate for cooking. Just enough cabinetry built for that stuff and to store the usual camping equipment, but it will be done with the lightest materials I can figure out or manage. It will have AC, probably a mini split, and eventually a bed, though I'll probably start out with a camping cot. Eventually a fold down mattress and table on the wall, and battery bank (maybe solar, probably just generator) for off grid. Will remove the plywood interior panels and replace with foam board insulation and paneling. I won't be adding a whole lot of weight to the basic trailer.
For size I'm looking at a v-nose trailer, 16' minimal length and 7' foot width. The 16' length will allow room for ATV (Honda Rancher 420) and motorcycle (Honda Shadow VT1100 for now), or possibly 2 ATVs, end to end with storage cabinets in the v-nose portion and along one wall. The 7 foot width because there isn't much to be gained by going narrower, and plenty of comfort to gain by going wider. Planning for 7' height being as I'm 6' tall and will be adding insulation and light fixtures to the ceiling. Definitely going tandem axle, likely 3.5k, with trailer brakes. As mentioned V-nose which will help with wind resistance, and thinking about adding slope to the v section in hopes that it will help a little bit more.
I'm not too concerned with the weight. With motorcycle, ATV, and gear it will be within the trailer's rated capacity and what my larger trucks can handle. With the Ranger I wouldn't be towing toys, no motorcycle or ATV, though they are only about 500lbs each so I think it could potentially handle one or the other. When towed with the Ranger it would be loaded safely within it's towing limits. My question more comes with how the Ranger will behave with pulling something that size.
How well will a Ranger handle towing a 7x16x7 tandem axle box down the road? It's a 1999 Ranger Extended cab. Originally a 4.0L 4x4 auto w/ 4.10 gears and ~30ish inch stock tires. Now a 5.0L AWD auto with 4.10 gears (considering 3.73 change) and to get shorter tires (think 2wd stance). Potentially a returning to 4x4 in the future if I swap the transfer case out for a 4406.
Towing with the Ranger wouldn't be normal mode. I want to retain the option if I wanted to go camping somewhere that I wanted the Ranger. IE a TRS G2G. There are areas that I'd go that I wouldn't want the toys and the Ranger would be more fun for Exploring than the bigger trucks.
