Carb problems
jjpp250
Central, CA
2.8 V6
5.5” + 2.5”
32/11.5/15 33/12.5/15
On the motor craft 2150 carb. What causes it to overflow at idle? And what is the little BB looking weight for?
Leaky needle and seat or a sunk float as mentioned above. Can't rule out fuel pressure either.
The bb weight if typically used as a check valve in the accelerator pump circuit.
Thank you guys, I have been trying to get this truck running well so I can decide what to do with it.
Would the float set to hi make run rich or flood when I put a load on the engine ( try to drive)
With the float level too high... it will be rich in all modes.
What are you using for a fuel pump?
Most carbs will only handle 3 to 7 lbs of fuel pressure.
With it running at idle... looking down the throat... is it dripping fuel from the venturies
