I am working on the pictures and stuff. There was a lot more modding than I expected to make things work together cohesively but I got it working. The wiring still looks like crap but it started first crank after the fuel bowl filled with gas.
I had to do a lot of grinding on the adapter plate to go from the Rochester to the Holley and I had to put new fittings and stuff on the manifold I got all that from lowes. The fitting on the top of the manifold to the left of the carb is where I ran my brake booster. The carb I bought has a connection for the PCV and the Vacuum advance for the Dizzy so I'm good with all my vacuum ports. Everything else is capped off.
I also took a file to the ports on the new manifold to make them all smooth and no burrs, so far it's a really good project I just want to get it buttoned up soon. My dad says he can hear an exhaust valve sticking but I think it's his imagination. I do think I have a head gasket leak, there is water in the oil, I'm hoping it's just from sitting for so long. I need to pull the head anyway sometime and check out the insides.
Yaz gots ta get a SHARTY header! Luv the cat yellr ps pump res!
