MadMike
I own a 2010 FX4 V6 4.0L with 4.10 gears that is all i know. Now the problem is my door code says i have an open diff 8.8" ring gear, but the manual says i have to put limited slip oil in the rear diff, soooo we did some tests one no brake peelout on the pavement from a stop two patches even all the way. Second doughnuts in the mud there was two rooster tails and had a friend watch from out side the truck to confirm, Third had truck in hard flex to the point were one tire was almost off the ground one wheel was spinning tire with most resistance. I dont really want to open the diff cause the truck only has 10K on it but i would like to know what the hell is in it (and also wondering if i have the 31 spline pinion) any help on this would be great thank you for your time
P.S all test done when i turn off TC in 2 wheel, also when in four low when truck was high centered all four tires were turning, I left it in gear and got out to look.
