Can't find body mounts with hardware....HELP Please!!!!!
DTMBENZ
Kentwood, MI
Hello everyone. I'm sorry if this question/answer has already be posted but I'm having trouble finding some parts.
I recently purchased a '93 Ranger Supercab 4x4 that has a 3" body lift that was installed incorrectly. I'm going to do the job right and install a 4" suspension lift and get rid of the body lift due to safety reasons.
So to get to the point, I can't seem to find any places that have body mount bushings along with the hardware necessary to install them. Has anyone run into this problem and if so, did you find a solution.
Thank you for any help you might be able to offer.
P.S.-Great website, I've already used it a bunch to help out with some of the known issues with this vehicle.
Summit has the body mounts, and all you "should" need are some grade 8 bolts that you can get at the local hardware store.
James Duff link has polyurethane body mounts (no lift). The set was cheaper than buying rubber ones individually (when I purchased mine). They have molded the metal liners into the bushings where necessary. You re-use the Ford sleeve with this set (instructions included). I bought grade 8 bolts from the local Caterpillar dealer when I replaced mine. Ford says the torque is 75ft-lbs for the bolts.
If you need the sleeves for one or two of the bushings (I did), Ford has them.
