Revvrnd
I'm new to TRS so forgive me if this has been asked before: I have an '87 Ranger 4X4 XLT w/2.9 & 5 sp. (Just picked it up a few weeks ago) Here goes: cold it runs fine but when it warms up it 'loads up' at about 1/2 - 3/4 throttle - especially if I'm just trying to maintain speed. When I got it the previous owner had replaced the TPS, MAP, tuned it up & still issues. I replaced the coolant temp sensor, o2 sensor, checked the cat (it had been gutted already), checked timing (it was off 5 deg and dist. was a little loose). I cleaned the EGR system - it was completely plugged. The engine has good compression and vacuum, the fuel pump maintains good pressure. We ohmed the injectors and all were good (one was .002 higer than the others) but, as a last ditch effort we swapped all of them with known good ones.
All of this to no avail - I am out of ideas. Oh yeah, as if this weren't enough, it is getting about 10 MPG and won't go over 78 MPH
ANy help would be appreciated!
