Tankpick
- Jan 25, 2013
- Automatic
Ok I have been trying to track down and fix a cyclic vibration on my truck for the past year and it's been driving me crazy. It happens at all speeds over 25-30 and gets worse the faster you go the trans does not slip and shits fine. Also there is audible clicking coming from the engine bay when under load but i'm not sure if that is related. I have searched many "vibration threads" so I have changed all the usual culprits. So far here is what I have done so far.
-All front end suspension components
-Different Rims/Tires
-New injectors
-New Spark plugs/wires
-New Ignition coil
-New Fuel pump/ pressure regulator
-New one piece drive shaft
-New upper/lower intake manifold gaskets
-New Front/rear brakes (rotors and drums as well)
-Both rear axle shafts have been swapped
-New torque converter/flywheel
-New DPFE sensor/hoses
-New Camshaft sychronizer (old one broke)
-New trans mount and cross member bushings
I have taken it to a highly rated shop twice for diagnosis and both times they could not track down the problem. I also took it to a aamco transmission place twice and they also could not pinpoint the problem either and both directed me at parts I have now changed.
So my question is does this seem like a transmission problem? I have the 4r44e btw. Any advice would be appreciated.
This is a 1996 ford ranger 3.0 extended cab 2wd with 125000 miles
-New injectors
-New Ignition coil
