Can someone verify my sadness?
kamps989
St. Paul, Minnesota
Timing chain cover leak? and if so does anyone know of a good walk through here or somewhere else or any snags I may encounter? Chiltons is useless for this. I am thinking I will just have to dive in and figure it out as I go.
Yes timing cover leak. No sadness.
The timing cover on the 3.0 is pretty easy. Remove fan and water pump, a handful of bolts, and anything else that is in the way, and it comes off. Should be done in a Saturday morning.
I would plan to replace the water pump while there.
Thanks for the speedy reply. I was thinking the same thing on the water pump. Any other things I should think about doing while I have the coolant drained out of it?
I went thru this last Fall. Here's your chance to do a lot of preventative maintenance; replace hoses, replace t-stat, flush radiator, fill with new coolant, install a block heater (this was worth every second/penny this winter), replace water pump, replace belt pulley and idler, replace serpentine belt, replace fan with elec. unit, etc.
I know this isn't a big issue but I checked the timing chain & it had slack !! R/R chain & sprockets-
