00srad600
When swapping the 2.9s between trucks the fuel system and your distbutor wiring have the same conetion are the same and will plug in together and make a simple motor swap vary complicated
my head hurts now .......
yeah i still don't know what you're talking about what does you putting in a new distributor have to do with the fact that you don't know what plugs in where if you knew where the old one goes that's where the new one goes if you don't know where the old one goes who the hell cares when you bought it why does this need to be stickied simple solution to this problem it's called masking tape it's a great thing to put on any wiring you disconnect i believe that this is something we refer to as a "self correcting problem" ie it won't happen again now will it 3 solutions to your current state if i understand what you managed to do which i don't think i do first plug them in which ever way you want start the truck 1 of 3 things will happen 1) the truck will run you hooked it up right 50% chance this happens 2) motor will turn over but no fire no harm ho foul 25% chance this will happen or 3) something goes BOOM/sizzle/smoke or some other combination of electrical mayhem 25% chance this happens second solution trace the wires for each connector back inside the loom, and find where they go and determine what should be connected those components third solution pull up a wiring schematic for your truck there's millions of them on this site a quick search will find the one you're looking for and look at the colors on the wires you have in the truck and the wires on the schematic
Your right masking tape would have helped but this was the 3ed time I had the motor out of the truck and never had a problem but when you troubleshoot what's wrong it makes it look like that you don't have a fuel problem cause the distbutor wiring opens the injectors and makes the plugs wet which make it seem like you don't have a wiring problem which is why I when and bought a distbutor and coil so sorry for something that I think might help someone else sorry if you could never make a simple mistake and get triped up on something simple
