can i fit 35's on my mazda b3000 with 3 inch BL
I may be wrong but with a 3"BL on a torsion bar front end they fit with a torsion bar crank. You may have some slight rubbing though.
i dont think so. i had issues with 33s with a 3'' bl. ive seen it done with a 4'' suspension lift with the 3''bl
i wouldnt do it... i have 35's on my truck and they just look good...
if your serious about 35's dont put them on your truck untill its re-geared. i threw on my tires thinking a 4.0 with a fresh re-built tranny would be ok for awhile but now my tranny is about to go again AND my rear-end too.
Really? I have 32's on my truck with zero issues and all I have is a t-bar crank!
heard that. im running 265/75/15s on mine. they are a little bigger than my buddys 31x10.50s and i have no lift whatsoever and no rubbing.
well right now i have 33s on it and no rubbing at all.. it looks like i can clear 35s to me but then again i dont know.. my truck picks up on the higway just fine also..
search...ive talked alot about 35's and 3" BL the past couple days...
rubbed inner fender, maxed out tbars, trimmed valence and front flares, was perfect on the street, but was definately not comfortable in wheelin it like that. I even had no flares and no valence.
Major fender trimming....major fender trimming. :D
You could fit the tires easily enough with a 3" bl and maybe torsion crank but gearing is going to be a major issue.
Even going to my 265/75's (31's) with my 3.73 gears the truck is a bit of a dog...
