greaseyfingers
Doing a code check on my Ranger revealed a code - 95- Fuel Pump Secondary Circuit Failure.
Being the frame rail fuel pump is working. Does that indicate the relay is functioning, properly, even though the in tank fuel pump doesn't appear to be working.
Does the relay send 12 volts to each fuel pump through the same wire? Or, are there two seperate wires going from the relay's wire connectons to each fuel pump?
