Nickmigues12
Hello all, I have a 99 Ranger with the 3.0 V6, that I am trying to install the camshaft synchronizer. This is a new engine, so previous position obviously didn’t help, so I set it at #1 TDC by both the spark plug trick as well as having both the valve covers and timing cover removed. I have it turned to about what appears to be 15 degrees, but it just won’t drop in the rest of the way. It has a new oil pump, but I had to reuse the old oil pump intermediate shaft as the new engine didn’t come with one. Do I need to shim my pump down? Is there another issue? I can’t find much info on my particular issue so any help is appreciated. Thanks!
