Camshaft spacer
micks84b2
Newark,Ohio
Anybody know where I can locate a new camshaft spacer for 84 2.8? I have had a hell of a time getting my top end to drip any amount of oil and after rebuilding the motor and replacing everthing but the cam spacer I have narrowed it down to that little metal ring causing my il to bleed off of the the front of the camshaft. Every dealership I have talked to said that they are not to be found anywhere but I refuse to believe that. Anyone know of a site that could help. Thanks.
Likely the cam bearings weren't replaced with the rebuild... OR the bearing with the oil passages was installed improperly..
As for the spacer is it loose or is it attahed to the gear cover?
Big JIm
I doubt very much if the spacer caused a problem. Was it scored or worn?
I'm sure someone has one from an extra engine - I'll look in my stuff, but I doubt it.
