lorenambrose
Autozone sells them "WITH" and WITHOUT" step on plug. The two look identical, so what is the difference. It could be a misprint as they call the part a crankshaft position sensor.
on the 3.0 it is called the crankshaft postion sensor, even tho in reality its a camshaft position sensor. your looking at the correct part, i cant help you as ive never had to change one just kno the correct terminology and placement. countless threads in the 3.0 forum on them fig i could relay you to the correct one for your problem.
Well if they are identical.. then just getcha one and be about your business..
Big JIm
